tool configuration between machine and polyboard |Forum|WOOD DESIGNER
April 8, 2026 - 10:10 am
Hello Emanuel,
You need to edit your post processor settings, and change the names of your tools to match Maestro.
You need to access your settings for:
  • Profiling
  • Cutoff
  • Inner tooling
  • Groove
In each setting, confirm that your tool name, and tool diameter are exactly the same as inputted into Maestro.
2026-04-08_10-06-47.PNGImage Enlarger
Emmanuel Sacco
Forum Posts: 199
April 8, 2026 - 9:32 am
Dear
I had to make few changes in the drilling head last week and when i am trying to put work on the machine the drilling is not matching and machine is not working .
thank you
Guest(s) 37
