Top Opening Cabinet for integrated Storage Bench seats|Forum|WOOD DESIGNER
June 17, 2025 - 2:48 pm
Hello Patrick,
You cannot change the front panel to “Present”, this needs to be added as a double back.
Also, if you remove the top panel you cannot apply a door.
Your only solution will be to apply hinges to a top panel to act as a door, although you will not see it in the simulation.
Sorry that I cannot help any more here.
Patrick Maylor
Forum Posts: 122
June 17, 2025 - 10:55 am
Hi Gents
I am getting a lot of cabinets that are integrated with a bench seat with an opening top.  I have been messing around rotating the cabinet to create the model but of course it will not render in the correct orientation to show clients and its taking far to much concentration.  Is there a way of making the frontage a panel (“Present” seems to be locked on “No”) and the top as not present and then add a door to the top?
Patrick
Guest(s) 29
