Top Rail method - Edging|Forum|WOOD DESIGNER
October 17, 2019 - 6:58 am
Hi, I understand now!
Don’t use Inner tooling to create Top rail!
Use Surface Split!
Example with your cab.
To start I have deleted the Structure on Top,
After apply surface split like in this screenshot
SS.PNGImage Enlarger
This method doesn’t delete the edge on the front
If you want to add an edge, you need to edit the Surface Split and select edge here,
After making the middle Nil you can add the structure to the lib, and add into Materials Style to have this when you create a new cab,
Struc.PNGImage Enlarger
Newcab.PNGImage Enlarger
Hope that’s helpful,
Blake Simpson
Forum Posts: 104
October 16, 2019 - 9:05 pm
Sorry not all steps were attached try – see updated attachments
Hi Alex
see attached pdf screen shots showing our method of creating top rails and applying edging to the front rail.
hope this helps
as it shows we end up with rails as we want but the front rail ends up edged to ‘all’ edges when we only require one front edge.
is there anyway of creating rails with edging to one edge only
Dave
Blake Simpson
Forum Posts: 104
October 16, 2019 - 8:46 pm
Hi Alex
hope this helps
Dave
October 16, 2019 - 6:49 am
Sorry but i don’t see anything in your attached cab,
Can you give me more information
and make a Polyboard update here,
Blake Simpson
Forum Posts: 104
October 15, 2019 - 9:55 pm
Hi
We have created top rails for our library of module base cabinets (see attachment). we have done this by applying a library structure (created – top rail) and changing mid section nil material. Not sure if this is the best or correct method but to add edging to front rail we can only do this we could find is to select rail – inner tooling – edit – select rail – add edging to Edging (Inner Tooling).
Hope this makes sense
But the issue with this method is the edging goes on ‘all’ edges and not just the seen front edge, found this out when the factory was coming to us saying the front rails are not long enough.
Can you please let me know the best method for creating rails where we can add edging to one edge only
Dave
Guest(s) 25
Topics: 3003
