Top rails as method|Forum|WOOD DESIGNER
Hi Stu,
Sorry for the late reply, we have been on holiday this last week and will only be back to work Monday.
To answer your question, no it’s not possible to create the top as 2 rails in a method.
The best way to manage this is to create a library of cabinets that have all elements that can’t be built into a sub-method.
I always suggest that once the manufacturing methods set up you use them to create a cabinet library that can be used as models to build projects. If you make a basic base cabinet with the 2 railed top you can load it, change the size and add doors, drawers etc as needed without having to add the structure. I would suggest you do the same for special cabinets like sink units, dish washer units etc that require specific set ups that are not manageable directly in a method.
Hope this is helpful,
Best
