Two colour on 1 panel |Forum|WOOD DESIGNER
May 23, 2018 - 7:29 am
Hi Hung and Michel,
Making the 2 colours on these panels with Polyboard will depend on the way you are going to build them.
If you are assembling 2 different panels then Michel’s solution will work however, I would say that generally you would veneer a base board with 2 different veneers.
In this case you’ll have to use the “Thickness split” commande first and then “Surface split” the veneer.
Here’s a quick video:
May 23, 2018 - 7:09 am
To have different colors on a panel without using surface split you must apply a texture to the material you’re using for the panel
texture2.jpgImage Enlarger
Here’s an example
and adjust it on left dialog box
text-aj.pngImage Enlarger
All the best, Alexandre
May 22, 2018 - 9:06 pm
Hi Hung,
This you can do with the surface split command in the editing part of the doors .
Here is a model
May 22, 2018 - 4:46 pm
Hello
Please tell me: how can i draw 02 colour on 1 panel like picture
ThanksTu-ao-chay-bang.jpgImage Enlarger
Giuong-chay-bang_LI.jpgImage Enlarger
Currently Online: Petru
Guest(s) 24
Emmanuel Sacco: 206
Zaheer Abbas: 197
A S Brighton
Tobias Briander
Topics: 3027
Members: 594
