two panel door |Forum|WOOD DESIGNER
OfflineHello Ryan,
Not in this specific example. You need to manually set the pocketing sizes for your CNC, therefore, this situation is not able to be parametric.
OfflineHello Ryan,
There are multiple ways to draw this door, and it depends on specifically how you construct it. Here are some examples:
1. Single panel, pocket door
2. Two panels, pocket through face panel
3. Assembled panels
OfflineHello Ryan,
Can you please send me a picture of what you would like to produce?
I will show you what options are available.
OfflineHello,
I am just woundering is there a way to draw doors with two panels quickly for example a tall door with a bottom panel of 715 match the base doors.
At the moment i just send one full panel door to vcarve and edit it on that before sending it to our CNC.
Thank you
Ryan
