URGENT REQ: Installation of 750 Blu Movento Runners|Forum|WOOD DESIGNER
OfflineHi Tom,
See this sorted in the following video. Additionally, the fitting is attached as well. All you need to do is import the fitting into your hardware list. Please confirm the drawer system with the spec sheet that I used.
OfflineHi Isaac,
Yes If you are able to help me add the correct screw holes for the 750 runner that would be great – the link was to the Blum website that’s all. A quick google search would do the job.
They are the 750 Blum Movento Undermounted Drawer Runners.
Let me know how and when we could sort this out.
Cheers,
Tom
OfflineHi Sean,
See below a link to a video outlining the basic design features of PolyBoard.
The following link contains multiple videos integrating PolyBoard and VCarve Pro with a dxf post processor.
Let me know if you would like any more information.
OfflineHi Tom,
The link doesn’t seem to work.
If the 750 drawers use the same runner system as the shorter drawers, then everything should work correctly. The only thing you can add is some additional holes for the longer drawer.
Let me know if you need support doing this.
OfflineHi Isaac,
Brilliant that’s really handy, learnt a few tricks there! Does this method for the drawers affect the location of screw holes for a 750 blum movento system? I export these onto my big CNC machine, so it’s important the screw holes are all aligned and it can be fit for a 750 blum movento drawer system.
Reference LINK: (EDIT: link removed as no longer active)
It’s really important I get this right for the lads to fit and install the cabinets, not just for the 3D. Really appreciate the support. I have some training hours available, if you need to quickly and manually install it to my desktop could that be arranged if not via the forum?
Cheers,
Tom
OfflineHello,
Here is my clients urgent request:
Room A is Hers, Room B is His.
Cheers,
Tom
