Volpato Gola fittings|Forum|WOOD DESIGNER
Zeljko Blascak
Forum Posts: 50
September 12, 2024 - 7:21 am
Hi Isaac, it is all working nicely.
Thank you
Zack B.
Forum Posts: 1452
September 10, 2024 - 2:45 pm
Zack,
Great. See the video I posted below the YouTube video in the previous post.
Let me know if you have any problems.
Zeljko Blascak
Forum Posts: 50
September 10, 2024 - 2:16 pm
hi
yes, that is what I want to do, same as in Youtube video
Zack B.
Forum Posts: 1452
September 10, 2024 - 11:58 am
Hi Zack,
I have tried to apply your fitting as shown in the following youtube video. Is this what you are trying to do?:
See what I have done below in PolyBoard:
Zeljko Blascak
Forum Posts: 50
September 10, 2024 - 11:13 am
Volpato-Gola-Cabinet.jpgImage Enlarger
Zeljko Blascak
Forum Posts: 50
September 10, 2024 - 11:12 am
hello
i don’t want to rotate the fitting, it should be same orientation as top and bottom, only need to fill the gap greater than 80cm
Here are the files
Zack B.
Forum Posts: 1452
September 10, 2024 - 10:45 am
Hi Zach,
So if it is bigger then 200cm you would like to rotate the fitting?
Would you please attach that file. I will open the file you are using and I will make a video for you using your cabinet and fittings.
Zeljko Blascak
Forum Posts: 50
September 10, 2024 - 9:39 am
Hello Isaac
I had follow the instructions and adjusted the orientation of the fittings (as you can see). It is working just fine for height up to 100cm. If I want to change the height to 200cm plus, I will need to fit few more fittings between top and bottom. Do I need to create different orientation of the Gola fitting or it can be changed  with different rules?
Zack B.
Volpato-Gola-Fitting-Applied-2.jpgImage Enlarger
Volpato-Gola-Fitting-2.pngImage Enlarger
Forum Posts: 1452
September 9, 2024 - 12:01 pm
Are you trying to create hardware rules that will add or subtract hardware depending on panel size?
I have examples of how to do this below:
Let me know if this has not answered your question.
Zeljko Blascak
Forum Posts: 50
September 9, 2024 - 10:44 am
I have no problem with creating the fittings and add them to the project or cabinet. I had added the screen shot of the Volpato Gola fitting that were added to the cabinet. Only, I need to add the rules that will add second raw of the fittings depend on the  with and length of the side panel. Also, I need to change these rules for cabinet or side panel that must be attached to existing cabinet.
Zack B.
volpato-gola-fittings.jpgImage Enlarger
Volpato-cabinet.jpgImage Enlarger
Guest(s) 34
brendan kavanagh: 227
Emmanuel Sacco: 196
Carl O'Meara
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2906
Members: 540
