wall import |Forum|WOOD DESIGNER
OfflineHi William,
Yes, it was made with a cabinet. You can add them all to the project mode, and add units to the room as you usually would.
See an example of this through the following link:
OfflineHello William,
Sorry, that file was created in the latest version of PolyBoard 8. You will need that version to view it.
You can also try this older file attached. Please make sure you have updated to at least 7.12d.
It is not possible to create sloping walls directly in Project mode, but you can create a large piece of furniture that will act as a room and allow you to model sloping walls, as in the library model attached below.
When you import a wall or floor DXF file in the project mode, it will always import from the Plan View (top view).
Therefore, this is not possible to import a sloping wall in this way.
Can you please attach the file.
