Wardrobe Project-First Project|Forum|WOOD DESIGNER
OfflineHi Ibrahim, here are your files. Please note, this is a file processing service only, we haven’t reviewed your Polyboard project before processing. I hope the build goes well, let us know how it goes and post some photos if possible. Thanks, Stefan
OfflineHi Ibrahim, is this the final project? Would you like us to send the cut list and plans now? Thanks, Stefan
OfflineJust a bit of extra detail to add to Ness’s comments. Your Premium Support covers help with specific questions you may have but for a full review of your project where we go in and find and resolve any issues, there is the option of ordering a support pack. For this, the 1 hour support pack would be sufficient.
If you would prefer not to have that review, we can send you your files whenever you’re ready. Just let us know… Thanks, Stefan
OfflineHi again,
I’ve managed to open your project in Polyboard 5, there seems to be a bug that is stopping it opening in Polyboard 6, the developers are working on it.
No problem to send you the cutting lists. When we send the manufacturing documents we always include the hardware lists, however you have no hardware applied so if you need hardware please apply a manufacturing method before we process the project.
For easier manufacturing and installation, I would suggest a few changes to your design :
– make the cabinet in 2 separate units, this will make the project easier to build and avoid the enormous “L” shaped panels that are used for top and bottom. These can not be cut from one sheet and will in any case need to be assembled from smaller parts. The same applies to the actual back panels that are very big.
– move the right hand separation so that you don’t have the extra wood on the shelves :
– add edging materials
– add recesses to shelves so that they are not touching the doors.
– add hardware and adjust the slack values of sliding doors to suit
– I don’t know where this unit will be fitted but have you added enough slack against walls and provided for fillers?
These are just a few suggestions, for a full revision of your project please consider using our professional support packs that you can buy here:
With a support pack we will have time to look in depth at your project and coach you through the design process and details to make sure that you have an optimised and buildable job.
hope this is helpful,
