From Sketch up 2017 and above, we have Quick plugin called Sketchup to DXF STL,
With this plugin, that's add menu (Tools>Export to DXFor STL) to export any sketchup to DXF 3D triangular mesh, working with Polyboad
Beware of too complex model could crash the Polyboard library, download and use this at your own risk
For example, to make tubes, use polygons of 12 segments maximum
Import in 3D acessory, single panel fittings
Included in zip, this example and skp plugin
Cheers, Alexandre
May 21, 2021
Hello everyone,
I already apologize if similar topic already exists.
Could anyone help me out and could show, how can be wtrer pipes and sewerage added to wall in correct place?
Also this is actual for electricity sockets?
Or it`s possible to import file from Sketchup?
Could you show also how to import it from sketchup
Thanks.
BR,
Girts.
