why is my middle door measurement different to the outside 2|Forum|WOOD DESIGNER
Forum Posts: 1452
February 4, 2025 - 11:42 am
Ben,
See attached:
ben levene
Forum Posts: 69
February 4, 2025 - 11:28 am
hi i am holding down cntrl and shift in cabinet mode and its not selecting all doors
February 1, 2025 - 7:42 am
Hi Ben,
This is normal as the door in the middle has on both sides a shared panel edge with the left and right door.
Let’s calculate.
You have a slack value of 1.5mm on the doors
The doors cover the left and right side panels by 18-1.5 = 16.5mm.
On the other side of these doors is the shared edge with the middle door. There, the cover value is 18/2 = 9 mm -1.5 slack = 7.5mm
For the middle door it is the same value on both sides. For the left and right doors, there is a value of 16.5 on the outside. So 16.5-7.5=9mm.
The door on the left and right side will be 9mm larger than the door in the middle.
If you want to have equal doors, select all doors by holding down the ctrl and shift key. When selected, right-click and select ” equalize doors and drawers size”.
PolyBoard will now recalculate the position of the uprights to reach equal doors. The result here is that the panels will no longer be evenly spaced, but this is normal.
ben levene
Forum Posts: 69
January 31, 2025 - 8:27 pm
i was wondering why my 2nd door (middle) has a different width when my uprights are evenly split?
Guest(s) 50
brendan kavanagh: 227
Emmanuel Sacco: 196
Carl O'Meara
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2906
Members: 540
