Need help whit my design|Forum|WOOD DESIGNER
Hi Reodor,
If you are asking for how to shape the handrail, there are an infinite number of possible shapes.
I suggest you go to you a local dealer or visit a web site and choose a profile that suits your style.
Here’s a video on a Festool profile set:
(EDIT: video no longer available on YouTube)
Hi Reodor,
Difficult to advise you without some more information.
Do you mean the style of handrails and spindles or are you thinking of completely replacing the railings drawn by StairDesigner ?
Can you send some photos of the room that the stair will be in, styles that you like etc.?
Hi Reodor,
I have checked you stair files and all the parts are coherent.
In the first set of plans, as step to post is set at 0, posts are lacking the step positions and the steps are lacking the penetration into the posts.
This is now corrected in the second set I just sent you.
To help you check and move forwards I attach the PDF print and dxf files of the modified steps and posts.
For your next stair I would suggest that you use our paid StairFile Pro service. This enables us to review you project in detail before processing it.
Hope this is helpful,
Reodor said
I can not use this program.
Also see that it is wrong on what has already been printed on stringers?
Need help for measuring
Hi
I do not get the steps to be accurate and the columns.
Printed drawings in full scale, but seeing that it is not correct.
There are panels and columns that are not consistent with respect to the drawings.
Due to the low height of the workshop can not I mount the stairs there.
Therefore, I have problems with the two miderste column.
need therefore I advice since this stairs should have been finished by now.
