Need help whit my design|Page 3|Forum|WOOD DESIGNER
Hi Reodor,
Can you send me an example ?
Hi Reodor,
Not sure what you mean, but if you mean, how to cut the step housings into the strings.
Have a look at the eBook How to “Make a Routing Guide” in the members library here :
https://wooddesigner.org/membe…..airs/core/
If Draftsight shows the printer in the printer list it should print normally.
To test, try to print to another printer.
If you can print to a PDF printer like PDF Creator you can try to print the plan from Adobe or another pdf program.
If you can’t get Draftsight to print to an installed printer there’s something wrong with the configuration of the printer within windows. I can’t really help with this, you might have to ask someone to have a look at your computer, unless some on the forum has come across this problem and can help.
good luck,
Hi again,
Have you installed the printer drivers?
