Riser or tread|Forum|WOOD DESIGNER
Riser or tread
Forum Posts: 984
October 6, 2017 - 12:37 pm
Hi Vanessa,
In this case I would choose the 13 steps. Why ??
The thread width of 230 is in the range of a comfortable step so if you can add on a lower riser it makes the stair more compliant
I used to prioritize the tread width as this comfort is more important than a riser of 190 or 200 mm. In cases to reach a better tread width I would choose the higher riser. In your case the lower riser still has a comfortable tread width.
Off course this remains a personal choice. The 12 steps variant you have works as well 😉
October 5, 2017 - 9:34 pm
I am designing a new staircase in my house, between ground floor and the basement. The basement is being renovated to be full living space. Half is above ground, so doesn’t feel like a basement. But there is limited space for the stairs.
Is it better to have more stairs with a smaller tread and a lower riser, or fewer stairs with a longer tread and a taller riser?
12 steps, riser – 209mm, tread – 250mm
or
13 steps, riser – 193mm, tread – 230mm
Which option would be more preferable when using the stairs?
Guest(s) 20
Duayne Naugle: 129
Patrick Maylor: 60
dziekan
AKM
Topics: 2095
Members: 258
