Hi Vidar,
Here are your files . I did not add right cut stringer 1 in the templates as it is a very small one that you can find perfectly doable with the workshop doc on page 23.
January 12, 2016
Hi Vidar
So you confirm that I can send you the documentation for this stair?
Also please confirm if you also need the 1/1scale templates for printing out the parts on paper and the paper width of the used printer.
If not needed you will get all files in dxf format and the workshop documentations.
Michel.
January 12, 2016
Hi Vidar
I closed the landing with risers but you cand add these elements also manually during the build. This is the way it can be done in SD7.
You cannot put the stair on top of the landing. To do so you have to make 2 projects. 1 landing and 1 stair and fit them together on the build.
I added risers on the landing and the last step to close the floor joint. Thickness I took is 11.5mm. If you have different sizes please correct them.
take a further look at all connections and penetration depths to see if it fits you to build
January 12, 2016
Hi
my handrail is 42 x 80 and the newelpost are 80 x 80 mm .
I looking at the landing maybe is better to Close it, would become a Place to collect dust under the landing and difficult to clean.
would it be easier to put the stair on top of the landing.
Everything else looks good.
vidar
Hi Vidar,
Ok this was a miscommunication as I thought the measurements were contained within the wooden construction around the stairwell.
Here is another example with a landing as a start. Please check the stair and the components like the handrail. Does this fit your demand?
January 12, 2016
January 12, 2016
Hi michel
I would like the stair to og the full lenght or i would end up With a small open Space between the stairstringer and the wall, thats where i see the problem becouse the floor has and overhang of 630 mm. I made a simple drawing for illustration.
Would something like the drawing be a good solution ?
The With of the stairwell is 1030 mm and 42 mm is my finished thickness.
vidar
Hi Vidar
here is a first stair and floorplan
I see no issue on the headroom as the space above the steps is free or where do you see the issue?
I shortened the stair to make both flights the same width and added a landing step with a riser on top to cover the floor joist.
You asked a stair width of 935 but did you take into account the newel post who is overshooting the stair on the handrail side? You also need sufficient spacing between the handrail and the side of the floor joist on ceiling height to assure a continuous grip.
What is the actual reel width of the stairwell?
The last point is the arrival of the stair. Is that an open space where the newel is situated? As you can see i set the newel half on the floor level to assure a good connection point with the floor.
About the 42mm. Is that the finished thickness? What shape do you need for the handrail and the bannisters? I based myself on the lower stair to design.
Let me know your findings
January 12, 2016
January 12, 2016
January 12, 2016
Hi Vidar,
I need from you all the needed information
measurements
pictures of what you like to have and pictures of the actual stairwell.
specifics that you need on the stair, like the needed sizes of components.
Once you have sen me this I will be able to start and revert with a first model that we then can discuss and adjust further
January 12, 2016
Hi just bought the design service. I was thinking of building a quarter turn stair but I have some issues with the headroom/staircase so I think it would be better to start the stair with a landing if that is possible then just a straight stair. Stringers on both side and railing and newel post to the right. Floor height is 2560 mm length is 3780 mm. Will be using 42 mm oak for treads without risers and 42 mm stringer board. With of the stair is 9350 mm Vidar
