Stairproject GZ|Forum|WOOD DESIGNER
Stairproject GZ
February 6, 2023 - 3:58 pm
Hi George,
There is no need to send anything. I was glad to help you out ;-). Actually, I am based in Belgium.
February 6, 2023 - 10:03 am
Hello Michel,
Thank you so much for your help.winkI am sorry for any inconveniences caused.  Unfortunately its like a new driver trying to drive a brand new vehicle, there is no substitute for experience gained.
I would like to send you something for your help are you based in the Henley Office?
Kind regards
George
February 5, 2023 - 6:49 pm
Hi George,
This is because you used the wrong type of stringboard. The correct ones should have been straight types, and you used “straight per part” type. This can have a position effect depending on the situation. You could see this in de stringboard view.
You have to check your designs as we only provide 1 set of documents. You got already 2 sets. This is now the last version that I am sending you.
  • sp_PlupMedia great-eye_final.zip(222 KB)
February 5, 2023 - 6:05 pm
Hello Michel,
Thank you for the files, after reviewing them there is a problem with top strings L3 and R3. The nosings and steps are not running parallel with the line of the strings I have attached a DXF with dimensions so you can see for the LHD string. NB the RHD string is the same.  Therefore, the stop newels and step will be out .  Can you advise. I look forward to hearing from you.
Many thanks
George
  • sp_PlupMedia Stringboard-Left3GZ.zip(39 KB)
January 30, 2023 - 5:49 am
Hi George,
With some delay, but here is your new set of documents.
  • sp_PlupMedia George-ZarembaV3.zip(221 KB)
January 26, 2023 - 8:49 am
George Zaremba said
Michel can you advise when I will receive a revised copy of the workshop drawings for this project ?
Is there anything else I need to do to move this forward ?
I would suggest a good update in the program would be to call the “Tread width”,  “Going” which is what it is.  Tread width is misleading as it is not included the nosing dimension.
Kind regards,   George
Hello Michel,
Thank you for the stair file,  upon receiving it and reviewing it, I have noticed that I made a big mistake.  I don’t  know what I was thinking but I assumed the going included the nosing and this is absolutely not so. So my going was 303.4 and should have been 273.4 .
I have redrawn from scratch the stairs and attach the corrected version.  I am really sorry to create additional work for you.
Kind regards
George
PS. The software is excellent, commendations to the developers and designers
January 23, 2023 - 6:05 pm
Hello Michel,
Kind regards
George
January 23, 2023 - 1:04 pm
Hi George,
Here is your stairfile
  • sp_PlupMedia Greateye.zip(213 KB)
January 23, 2023 - 10:15 am
Hi Michel,
Thanks for the updated version.  I confirm that everything that the length of the stairs are correct. A final short step will be added on the landing to take the 56mm into account, I could not see how you would do this in the application.
KR
George
January 23, 2023 - 9:48 am
Hi George,
you have to upgrade to the latest version
so you mean that the last step should be inside the 5158.2? If so it needs to be changed
Currently Online: LORIN STANCIU
Guest(s) 91
Javier Velázquez
sjust
Topics: 2933
Members: 554
