180 degree turn with two quarter landings|Forum|WOOD DESIGNER
Hi Michael, please go to the StairDesigner download page to install the latest version – thanks.
Hi Michael ,
I attached an example you can use to work out your stair . It is done in sd7 the latest version 7.06A
I used model 9 to start and added flights and landings to reach the result.
I have a couple of stairs to produce with a 180 degree turn comprising a straight flight up to a quarter turn, then a two tread flight, then another quarter turn, and finishing with a straight flight to a trimmer.
Would I be right doing this in multi flight stairs, and if so, is there a tutorial for version 7? I have found one for V6 but not sure how relevant that is?
There doesnt seem to be anything in the libraries for this.
Ive attached a very rough sketch of what I need to make, can you give me some pointers? Download double-quarter-turn-stair.pdf
