changing parameters|Forum|WOOD DESIGNER
changing parameters
Forum Posts: 918
May 21, 2015 - 9:14 am
Hi Jan,
If you haven’t already, please check out the basic StairDesigner videos here: https://wooddesigner.org/suppo…..er-videos/, especially the ones on Getting Started and Stair Parameters (Part Properties).
Here’s a link to the forum thread Duayne mentioned which is also very useful: https://wooddesigner.org/forum…..tair-rule/
We can certainly design the stair for you too. You would need to upgrade to Full membership, then purchase either the StairFile Pro service (you do the design in StairDesigner, we review and revise it if necessary) or the StairPlan service (just send the spec and we do the design for you – no need to use the software yourself at all). Click here for more info:
https://wooddesigner.org/stair…..n-service/
Cheers,
Duayne Naugle
Forum Posts: 129
March 1, 2015
May 21, 2015 - 2:40 am
you need to change the stair rule , it was explained to me in the stair building forum under “Stair rule “, check it out !
 A rise of 8″ and a run of 9″ will get you very close to the 42 degrees that you are looking for .
May 20, 2015 - 6:24 am
My stair does not fit in the setup required for a good stair as used in the program. It needs to be a bit more steep, like 42 degrees.
Is it possible to change this and is there a video to show it?
If not can you still design the stairs for me with my details?
Guest(s) 27
Duayne Naugle: 129
Ray: 59
Patrick Maylor: 57
dziekan
AKM
Garyh
niharbu
Daniel Jones
Topics: 2075
Members: 254
