Cut String-chamfer milling does not subtract the cutter radius. |Forum|WOOD DESIGNER
OfflineHi Ain,
I have sent you an email following up this question.
OfflineHi Puuslik,
Could you please send me your PP and your stair file? I will have at look and these files and try to find where your problem is.
You may not be able to send the PP file via the forum, if that’s the case then please send it via our contact form.
Please make the subject: Forum files for Isaac.
If you need help saving your PP, please see the following image:
With the output, are you referring to the DXF2D extruded export or the DXF3D?
OfflineHi !
Problem with milling cut string inside corner under slope.
Milling is necessary in the corner minus the blade R. Tool D 15.7 mm on jpg.
How can I fix it?
I downloaded the new version of Stair Designer 7.17e Pro PP to my computer but “3D DXF Per Part” is not available in the export options, how can I get it back? Unfortunately, I couldn’t back up the old version.
Ain
