Cut String|Forum|WOOD DESIGNER
OfflineHi Richard,
Sorry for the delay on the response. We had a hectic week 😉
I am glad you found the solution
SOLVED!
Terminology: I did not know there was difference between cut string and a stringboard. I assumed I could turn a stringboard into a cut string.
Hi
We dont use the software that often but are looking for the answer to the follow:
We wish to make the string highlighted in green on the attachment a cut string not a straight string.
Just need the menu item (location) in the software to make the adjustment.
We have downloaded the latest version 7.15f
Richard
Guest(s) 32
brendan kavanagh: 227
Emmanuel Sacco: 196
Carl O'Meara
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2906
Members: 540
© Simple:Press —
