Default settings|Forum|WOOD DESIGNER
Default settings
Forum Posts: 5
May 25, 2026 - 12:37 pm
OK I will try that
Thank you Isaac
Forum Posts: 1441
May 25, 2026 - 12:22 pm
Hello Abbi,
Your best option in this situation is to build your winders with landings in StairDesigner. This will allow you to use your specific standards as you build your stairs.
See the attached model as an example.
Forum Posts: 5
May 25, 2026 - 11:55 am
Hi Isaac
I’m not sure what you are saying, the programs winder staircase control values are not designing a winder tread that is legal in Australia, we require the inner winder run to be a minimum of 150mm regardless of any other dimensions in the treads.
Abbi
Forum Posts: 1441
May 25, 2026 - 11:16 am
Hello Abbi,
As described in our documentation, tread dimensions are auto calculated via a flight length and your control values. They are not manually inputted. To manually add any tread dimensions, this would need to be completed via adding individual landings and manually setting your dimensions.
Control values information
Forum Posts: 5
May 25, 2026 - 11:09 am
Hi
I am unable to change the tread dimensions and this is a function that I need to design my stairs within the perimeters that already exist in my house, I thought I was subscribing to a full functioning program.
Without this ability this program will not work for me.
Abbi
Forum Posts: 1441
May 21, 2026 - 10:45 am
Hello Abbi,
This information will be available to change in your properties, and the manufacturing methods. See the following information:
Manufacturing methods
Link parameters
See further StairDesigner tutorials here:
Forum Posts: 5
May 21, 2026 - 10:35 am
timber settings & tread settings are not available for me to change
Forum Posts: 1441
May 21, 2026 - 10:30 am
Hello Abbi,
What settings would you like to change?
Forum Posts: 5
May 21, 2026 - 10:20 am
Hi
I seem to have some default settings that I cannot change in my stair design
Abbi
Guest(s) 75
Timothy Bennett
Members: 536
