dfx Orientation and price calculation currency|Forum|WOOD DESIGNER
Hi Ott,
For DXF output it depends on whether you are talking about StairDesigner of Polyboard.
For StairDesigner 7, for the time being you can’t change the X/Y output of the DXF files, so this has to be done manually before adding tool paths.
The developers are working on a Pro PP version that will have a lot of extra features for machining but this will not be ready for a few months.
For Polyboard you can use the “Orientation” option in the PP setup:
The € sign is dependant on your Windows set up. If you set up the windows currency to be $ Polyboard and StairDesigner will use the $ sign.
Hi Ott,
There is no possibility to my knowledge to have the dxf outputed in another direction. Also the euro sign is not changeable. I do not know if this will be an added feature in stairdesigner in coming versions. This is something Ness can answer on.
