File my stair project|Forum|WOOD DESIGNER
Hi Roar,
Here is your stairfile
Hi Roar,
You need to be sure of the design before you ask for documents as you are entitled to only 1 set of documents free per month. I will check this one but be careful in the future. Stairdesigner is showing you clearly the size of your flights and if the landingstep is included or not. In this case, the landingstep was not included in the design.
I have corrected it so now please check every detail so that it is correct for you before asking the documents again. I also added a third version with correction I did to it. It is up to you to see which version suits you the best
Hello. I have misunderstood something and done something wrong in stair designer. The stairs have become too big in relation to the stairwell it should be. Can you help me ?
I will build the stairs with 22mm chipboard all over it and cover it with 26mm oak on the steps and use 16mm on the risers. Has therefore taken this into account in stairdesigner and drawn this in autocad afterwards. (as you can see in the attached pdf)
Have attached a pdf with the measurement it should have had.
Kind Regards Roar Borgen
