how do I add a large post 9"x 9" to the inside corner of a set of winder stringboards|Forum|WOOD DESIGNER
Hi Mike,
Very nice stair !
all the best,
Thanks for adding these for me, these stairs were manufactured from left over logs that the customer had for his project. The logs came from an old barn that was dismantled and he reassembled into a nice little cabin on the river near Calabogie Ontario, Canada. The logs are well over 150 years old. We milled them with our sawmill and then turned them into this beautiful set of live edge stairs for him. Thanks for the help and i look forward to working with you on our next project.
Hi everyone,
I love Mike’s work that is not only limited to stairs.
Everyone should look at his website to understand the way he works :
(EDIT: link no longer active)
Great job Mike!
Have a great Christmas.
Hi Mike, images need to be quite small for the web. If you click upload attachments, you’ll see the max file size and dimensions the forum accepts.
A quick way to do it is to use an online service like: https://www.picresize.com/
Upload the image, then in this case pick a custom size of 600 x 800 pixels (or 800 x 600 say if landscape), and it should easily be small enough to upload without a problem.
Any problems, let me know.
Edit: here they are. Nice job, Mike!
Looking forwards to seeing the finished stairs.
Hi Mike,
Here are your files.
Enjoy the build and keep us updated.
yes the steps are thicker than the stringers. I am using old reclaimed barn beams that I am making the stairs out of and the longer pieces for the stringers i had to mill thinner than the rest because of some rot and large cracks. I had to go to the center of the beams to get solid wood. As for the other suggestions that works for me. Thanks
