How to get fixed banister distance?|Forum|WOOD DESIGNER
OfflineHi Roar,
It is not possible to disable a setting. Only change the value. There are 2 modes. Equidistance and fixed gap. This is always calculated regarding the step-nose otherwise you would encounter bannisters being set on a wrong spot just to keep the space even. You will always encounter differences in this kind of stairs unless you have only straight steps. The differences are mainly generated due to the winding of the different steps.
How can I get the same distance between al the banisters? In my stairproject the stair turns and then the distance get to long between two of the
Guest(s) 19
Topics: 3003
© Simple:Press —
