Is there a way to configure the default settings for treads and risers regarding dimensions?|Forum|WOOD DESIGNER
Forum Posts: 2100
August 9, 2024 - 10:57 am
Can you send your Stair and output file for better analysis, like this I can compare with my output
Which output are you using?
For noising you have 2 setting from your stair and from PP
Noising.pngImage Enlarger
Yohaan Chandra
Forum Posts: 22
August 9, 2024 - 12:49 am
We build stairs differently in New Zealand compared to the UK and one of the main problems we run into is the wrong tread sizing. i will attach photos for reference.
our treads stop at the start of a riser ( refer to red line drawing in photo 1 ) and stair designer only gives us tread dimensions of the black line ( please refer to photo 1 ).
so each time we cut out or treads we have to manually calculate the real tread size as most of our stairs are carpet grade and we allow 25mm for nosing and have made mistakes in doing so which cost us alot of money and time.
i am looking for a solution for this, maybe there is a way to customise the method of stairmaking so we can remove the manual calculation out of the equation and follow a cutlist exactly.
i also have taken a look at each individual step to check the dimensions given and those also do not align with how we make the stairs.
Screenshot-2024-04-19-144403-4.pngImage Enlarger
Screenshot-2024-08-09-114334-1-1.jpgImage Enlarger
Guest(s) 45
brendan kavanagh: 209
Zaheer Abbas: 156
Patrick Maylor: 114
Tom Jackson: 113
Cristian mihoreanu
Jurij Avizen
H
magnus rehn
Stephanie Olaverry
Gustavo Muñoz
Maciej Jaworski
Eleanor Maple
Topics: 2755
Members: 477
