Landing on first step|Forum|WOOD DESIGNER
April 14, 2016 - 10:16 am
Hi Aaron,
I have set up a revised model of your stair, the file is attached to this post.
However, as Stefan has said your stair project requires in depth revision that is outside the scope of our free membership.
Please consider buying a StairFile Pro service and we can help you set up this project.
3d010.jpgImage Enlarger
April 13, 2016 - 11:11 am
attached is my project. however i am not happy with the outcome.
1. the first step should be 1.06m x 1.06m
2. the going i want it to be approx 30cm for the straight step but it comes more.
Stairs height is 3.250m
May you help me please to adjust it?
Aaron
Forum Posts: 954
April 12, 2016 - 2:56 pm
Hi again,
StairFile Pro is £95 on top of the £10/month membership. We’ll review your design and revise if necessary, but we don’t do the design for you, rather we help you with it.
Cheers, Stefan
April 12, 2016 - 2:50 pm
Stefan said
Hi Aaron, have you checked out the StairDesigner videos? This one on adding a landing to your stair should help:
https://wooddesigner.org/membe…..-landings/
Please go through the videos and see how you get on. If you eventually decide you would like us to work on the design with you, do consider paying for a StairFile Pro, you need to be a Full member too to access it:
It is a very quick way to get the stair designed accurately and to make it as easy to build as possible. If you are using the software for a one off project, it’s a very affordable design service that minimizes the risk of errors in your plan.
Otherwise, please let us know how you’re getting on.
All the best, Stefan
Hi Stefan,
Thank you for your reply.
how much would cost me if you design me my stairs?
Aaron
Forum Posts: 954
April 12, 2016 - 2:45 pm
April 12, 2016 - 1:47 pm
Dear all,
I am new in this Forum. I am designing a new steel stairs for my new house but i am using the Stair designer software.
My stairs is a u shape stairs and my first problem is that i can’t manage to draw the first step which is a landing of 1 x 1m.
Kindly i need your help.
Aaron
Currently Online: Tom Jackson, Isaac
Guest(s) 40
Timothy Bennett
Members: 536
