Hi Hasse
on the grum project you indeed add a length beyond the last step on 70. This adds 70 mm to the total length so you have to deduct it from the original length. You do not see the step as you only choosed a lengthening of the stringer but in view steps or 3D you can see the step and it is measuring 70mm
You can choose to add a landing by right click on the stair page in 2D and then choose add a landing. You will have to add also the cutstringers but enter the same values as the other stringers ( width , height , offset). You will see that stairdesigner will join them as 1 cutstring. Same for the handrail. You will now see the step in the 2d also. I added 2 pictures showing the version with and without landing and the step
On the peter K the flight is too short on the right side to get a stringer . You have to add length and change the connection to mittred as this is giving the best results in this case.
If any further question let me know ;-). I also added both stairfiles
Hasse Svensson
February 18, 2014
Hello.
I have made 2 projekt in ST7 and wonder what´s the differenc.
Projekt "Peter Kronvall" I have50 mms landingstep and I can see it on the layout and its also masure 50 mm inklude the total lengd of flite I have put on 2250 mm
The other projekt " Grums SWF" I have put lengd beyond last step 70 mm but Its not show stepp 15 on the layout and it not measure 70 mm.
Probably I missed to put some measure of landingstep when I opted "New Stair" of the startmenu.
The total lengd of 3rd flite are 2029 mm but I had to counting off the 70 mms.
How do I change it in "Grums SWF" so I can see the landingstep on the layout?
( With layout I mean when I clic on "print prewiev"
Ond more question....
In projekt "Peter K..." I can not see cutstring no 1 right.
It some measure to short?
Best regards from Hasse in Sweden
