my first stairs|Forum|WOOD DESIGNER
Hi Jens
here are your files
Hi Jens,
Attach the version which is final for you on a post and I will provide your stairfiles
Hi Jens
please upgrade your version on the website
We have the latest version now there 7.12e. You should then be able to open the files you got from Ness.
Hi Jens,
Before I send you the plans for this stair there are several points that might need adjusting.
– step and riser housings are 30mm deep this is generally too deep and 15mm would be better
– no step and riser penetration into the posts, this should be set to the same as the string penetration
– no riser to upper step penetration this should be set to around 10mm
– first left string flush to the first step nosing, the stringer should be put forward so that the step housing is not exposed
– first handrail is 40mm thick like the stringers but the 2nd is 50mm thick, is this done on purpose?
Some other suggestions:
– Risers are sitting on the steps, they usually go behind the step and are screwed from behind
– Step housings around the post are not optimised for machining, it’s better to move steps so that the housings are fully contained on one face of the post or stringer.
– riser N° 12 housing not contained in the stringer, the stringer should be eased to allow the housing to be contained within the stringer width.
– Right stringers are curved, in this stair it would be better to have them straight.
One other points that are unclear for me :
– step 13 is straight with no landing step with the last riser half notched into the post. It would be better to have a landing step and have the last riser notched into the stringer.
– First step is 200mm thick, is this an error?
– handrails are unusually wide at 120mm, is this really what you want?
– strings and handrails penetrate 30mm into the posts, is there a reason for this. I would suggest that you cut them flush and use a dowel and bolt assembly.
I attach your stair with these modifications for your appreciation.
