Nosing Problem|Forum|WOOD DESIGNER
michel melon said
Hi Kevin
I see no file attached? However, if you want to change the nosing on all steps you must be sure that you did not select a step as it will change for only that step. In order to change all, no selection is allowed/ You can then enter the step parameters and set it to the desired value.
In case it is something else please send me the file and explain what you did
Hi Michel,
I have selected all treads in general to have 20mm nosing, I then just export the Stringers and treads via VCarve dfx. The nosing on the treads is correct but on the strings the nosing is 30mm.
I did add an attachment but will do so again.
OfflineHi Kevin
