Project stair|Forum|WOOD DESIGNER
Project stair
January 23, 2023 - 1:16 pm
Hi Thijs,
You can see this when you select the flight it colours the flight. It is visible that the last step is not included.
flight-selection.pngImage Enlarger
To set the landing step inside the flight measurement, you have to right-click and add a landing with the position in the stairwell. You only extended the stringboards, which automatically handle the extension outside the stairwell.
New files attached
January 23, 2023 - 11:14 am
Hi Michel,
I now noticed that the program added 100mm to the lenght of flight 2. I now see thats because off the landing step (you can’t see this dimension in demo mode, nor do you a warning of this ). This makes my stair to big for the room i have. Can you make the attached stair smaller in that length so that i have from left side of the stairs to right side of the landingsstep riser 2962mm length in flight 2? (i attached also a drawing explanation of this )
greetings
Thijs
wooddesigner2.PNGImage Enlarger
January 20, 2023 - 2:59 pm
Hi Thijs,
Here is your stairfile
January 20, 2023 - 1:48 pm
I would like my files form my stair project so i can change it to a z stairs.
With kind regards
Thijs
Most Users Ever Online: 704
Guest(s) 130
brendan kavanagh: 198
Conor Devoy: 158
Zaheer Abbas: 152
Patrick Maylor: 108
Emmanuel Sacco: 106
Blake Simpson: 104
Nathan Bruton
Michael Okyere
Timo Pitkänen
jose andres durango medina
Dag Lislerud Midtfjeld
Rejmond Islami
juan cabezas
Michael Dyer
ALEJANDRO PALACIOS RODRIGUEZ
David Filiba
Topics: 2697
Members: 463
