January 29, 2015
Thanks Stefan,
It's always nice to know where to find support.
I'm pretty sure I'm exaggerating but I like the expression "Better safe than sorry".
My extra support at the top will soon be in place, but an expert opinion afterwards could be intresting even though I already made my decision. There might eventually be other who wonders if I was doing right or wrong 🙂
Best Regards
Petra
Hi Petra, sounds like it is a bit slow going, but perhaps a good strategy as you say to leave some of the other stuff to your husband!
Let us know if you want to talk about any of it. All the best, Stefan
The following users say thank you to Stefan for this useful post:
Petra Lindelöf
January 29, 2015
I really do understand why stairs are so expensive. As an amateur (even though I have had an excelent adviser) there is new issues coming up all the time.
Is it strong enough?
Support, support and some extra support an amateurs life
If you are curious please feel free to take a look at my long term project.
https://petralindelof.blogspot.....tails.html
I'm not sure but eventually I work so slow just to avoid all the other work which my husband is doing. As replacing a door, put all the electricity inside the brickwalls, rising a new wall and even more.
All the best
Petra
The following users say thank you to Petra Lindelöf for this useful post:
Nice to see the stair rising!
Great to see how your stair project is going. Thanks very much for sharing!
January 29, 2015
January 29, 2015
Wooden templates are made for the steps and I'm practising with a new toy
December 31, 2014
December 31, 2014
Hi Petra and Christopher,
Nice to see the stair slowly growing!
For Christopher I did post the last designs files you can see them from earlier on in this thread. Be sure to be logged in or they will not show up.
The last design that we worked out was this one:
General specs were worked out on previous designs using StairDesigner and SketchUp.
The 2 work well together to test designs insitu:
For those that might be interested in this I've uploaded a zip file with the design elements.
Looking forwards to seeing the stair finished Petra.
December 31, 2014
January 29, 2015
Hi All,
Slowly, slowly our new stair is taking shape.
For all amatures like myself, I must say, with stairdesigner you get a possibility to build your own stair. Well I haven't reached the goal yet but there is hope.
Some photos are uploaded at my blog.
https://petralindelof.blogspot.....stair.html
Best Regards
Petra
January 29, 2015
Thanks,
I think I got a french version but I can probobly figure out what the words mean. The figures are at least in mm
I will try to open the dxf in my light verson of cad so I get all the measures. Is the pdf meant to be printed 1:1 and used as a fillsize template?
The left stringer at the first flight I will lengthen towards the wall as you proposed and make a post under the right stringer or in worst case attache the whole stair in the wall...
This will be great (I hope)
Best Regards
Petra
Hi Petra,
The strings will be OK to build from 66x315 but as always with stairs with winders, you'll have to glue extra width on the sections supporting the winders.
I attach the final StairDesigner files for your approval.
Note that the shape of the stringers should be edited to make them flow better and easier to build.
January 29, 2015
Hello Petra,
Your stair looks fine like this . I have just adjusted a little the winders so that they are spread more evenly around the turning and move the last post forwards so that the last step nosing is not flush with the post face .
If you are OK with this last design I can send you the manufacturing files.
January 29, 2015
Hi again,
My height calculation wasn't that bad
We will keep the beem in the celing almost as it is which means the hole will have a width of 760mm. So we keep the stair width at 800mm and adjust tha last step to fit between the wall and the beem.
The newel post in the inner corner will be placed under the beem where it will be cut of to make the hole a bit L-shaped. I made the first flight a little shorter so there is less impact of the window and a not so many steps without handrail on the right side. The handrail for the right hand on second flight we will make when the stair is in place. And there will be a wallmounted handrail all the way up on left hand.
I have rounded (again) the steps on right side and will use a tool for which I don't know the english word to make a nice oldfashion shape on the front and right side of the steps.
Does this sound like a possible plan? and please feel free to correct my stair (again) if you have any hesitation about my recalculation or shape of the steps...
Best Regards
Petra
Hi Petra,
Without a handrail on the second flight your stair will be quite dangerous.
On the other hand you could take away the first handrail.
Making the stair wider is possible but 800m wide is already not bad for a normal stair.
Be careful if you make the stair wider your stair well will also have to be wider!
We'll be waiting for the next installment!
January 29, 2015
Thanks,
It's a good thing to picture the stair i the room. It will be a pretty narrow stair. Agains all better knowing I'm tempted to remove the handrail and stay with a wallmounted handrail or second choise is to make the stair wider. At this point I wish I had the skill to make a lovely curved stair
We will start up the project and make the hole. Be aware... I'll be back...
//Petra
Hi Petra,
I've made a quick SketchUp drawing to show how the stair will look in the room:
As you can see the stair stringer looking face on hardly covers the upper left corner of the door. This wouldn't be an issue even if the stringer was against the wall. But looking at your photos, it will mean that the door will only open to 90°.
Your design should work fine . Note that to stabilize the stair, you will need to anchor the end of steps 6 and 7 firmly on the wall. However the joint between the stringers will be taking a lot of strain and might with years begin to play.
To avoid this and make it unnecessary to fix the steps on the wall you might consider making these 2 modifications:
1- extending the first left string to the wall:
We cannot add this in StairDesigner so you'll have to add it either by editing the DXF file or by hand on the PDF print outs.
Note that you'll need to edit a bit the shape of the cut strings so that they jon harmoniously.
2- extending the corner post to the floor:
This will make the stair nearly free standing, only fixed at the start the end of the first stringer into the wall and at the first floor.
The stair would be perfectly stable with no risk of play in time.
I attach the SketchUp model .
Petra Lindelöf1 Guest(s)
