self supporting |Forum|WOOD DESIGNER
Hi Duayne,
Sorry for the delay on this. Can we have a zoom meeting to work on this just to be sure we speak about the same issue. When are you available?
Depending on your location we have to consider the time difference
Hi Duayne,
Yes, you can extend the stringer by setting the offset in the stringboard parameters. You will have to add the same amount on the stringboard width to put the stringboard in place.
March 1, 2015
i have a stairway to build , an open stairway that has walls around the outside but is open on the inside , I would like to have the 1st and 2nd flight have it’s inside skirts extend to the wall , can i do that in stair designer ?
4 steps up to a landing , turn 90 degree to 4 more steps to a landing which turns 90 degrees to the finial 4 steps
