Stair Enquiry|Forum|WOOD DESIGNER
Stair Enquiry
May 19, 2021 - 3:48 pm
Hi Geoff,
Here is your stairfile
May 19, 2021 - 8:14 am
Hi Michel,
I did check penetrations, they should be 13mm into strings and newel posts.
Please find finished file attached below.
Many Thanks,
Geoff.
May 19, 2021 - 7:49 am
Hi Geoff,
Did you check your penetrations?
steps are penetrating 30mm in a springboard of 32 mm ??  A general rule is 1/3 penetration so in your case 10mm is the value for the penetration.
can you have a final check on this and confirm?
May 19, 2021 - 7:12 am
Hi Michel,
This looks fine, Thank you for your help, All I need now is the stairfile and DXF files to manufacture the staircase.
Many Thanks,
Geoff.
May 19, 2021 - 6:44 am
Hi Michel,
Many Thanks,
Geoff.
May 19, 2021 - 6:21 am
Hi Geoff,
You can shape the bullnose step in many ways. The issue is that the riser will not follow the step shape so you will have to add this on manually. Using the 2D DXF  of your stair on a cad program to add the riser and penetration point on the stringboard and eventual the newel. This requires some cad intervention but you could create a riser that is not penetrating these elements which will make it easier for you.
I shaped a bullnose on it. The best way to do it is to go to the step overview and shape the step directly in the editing mode ( double click on the step )
May 18, 2021 - 4:51 pm
Is it possible to have the stair file and DXF files so I can manufacture this staircase please.
The Client has requested a bullnose step at the bottom, but I am not sure how to put it in correctly in the programme, so can you please have a look at this for me.
Many Thanks,
Geoff.
Most Users Ever Online: 704
Currently Online: mark nichols
Guest(s) 53
brendan kavanagh: 205
Conor Devoy: 158
Zaheer Abbas: 154
Patrick Maylor: 108
Tom Jackson: 106
Stephanie Olaverry
Gustavo Muñoz
Maciej Jaworski
Eleanor Maple
Filip Godu
Erik Rickert
Brandon Januarie
David Triller
Nathan Bruton
Topics: 2727
Members: 472
