Stair number 3 for Pete Rip!|Forum|WOOD DESIGNER
June 11, 2017 - 12:27 pm
Hi Michel.
Brilliant, thanks for the files. Will upload some pics when done.
Thanks for sending this back so quick.
Cheers.
Pete
Forum Posts: 984
sp_UserOnlineSmall Online
June 8, 2017 - 6:00 am
Hi Pete,
Here are your doc’s.
Have fun 😉 and send back some pictures when done
June 8, 2017 - 1:07 am
Perfecto!
All of your points accepted- and yes, thanks for the 15mm as apposed to 30mm penetration. much more sensible
Don’t worry about a riser on the top step. I will work that out on site.
If you can press the GO button on your machine that would be great.
Thanks for the fast turn around!
Oh, the new SD7 is great. a big leap forward for you guys.
Cheers,
Pete.
Forum Posts: 984
June 7, 2017 - 6:05 pm
Hi Pete,
Here is a version. I changed some parameters.
penetration of steps from 30 to 15 mm
same for the stringers from 30 to 15mm and changed the connection type to the newels  that gives a better finish after build. Let me know if you like it
lengthen the stringer by 20mm passed the first step.
changed the position of the first newel to get in line with the right stringer overpass
added a landing step in the stairwell so that the length of the fligth remains the same
arranged the australian winder with a kite step ( I had to remove 1 step from 17 to 16 ) to get it. In your other version it was also 16 steps and there was a different floor height ??
you can also choose to get a riser on the last step only. Do you need one?
June 7, 2017 - 3:18 pm
uploading again. previous upload didn’t seem to work.
Forum Posts: 984
June 7, 2017 - 12:54 pm
Hi pete,
i reply this evening when I am back home
June 7, 2017 - 12:47 pm
now with stringboards..
June 7, 2017 - 12:44 pm
Hang on. String boards…Will upload shortly with stringboards…
June 7, 2017 - 12:42 pm
Hi Michel.
Please find SD7 file attached. I can not work out how to make the winders Australian compliant. Ness has fixed this for me before.
Basically we are allowed only 3 winders. The middle winder must be kite shaped. All other stairs above and below must be square.
If you have a look in my previous upload you can see what I mean.
Cheers and thanks.
Pete
June 7, 2017 - 11:29 am
Hi Michel. Yep, after files please but I will re-enter the numbers as per your suggestion and upload the files this evening in SD7
Pete
Currently Online: Michel
Guest(s) 21
Duayne Naugle: 129
Ray: 59
dziekan
AKM
Garyh
Topics: 2089
Members: 257
