Stair project - plans in dxf pls|Forum|WOOD DESIGNER
OfflineHi Zeljko
here are the files
OfflineHi Zeljko
do you need the DXF processing files ?
OfflineHi Zeljko
Your stair probably fits but the drawing is very small so I can almost not read it. I would like to know what your problem is with the balustrade. I guess you mean a balustrade on the first level. This can be done in SD7 with some workaround. For that I need a clear view on your drawing . Can you send one with a higher definition as this is only a 40kb file.
Your top newel should be connected to the stringer to create a strong connection. Just put on top weakens the strenght of the newel as there is not a strong fixing point.
OfflineHi Zeljko
Sorry for the delay. I see some issues on the stair. There is no need to remove the last step as per default sd7 does not apply a landing step unless you specify it.
Send me a drawing of what you need to achieve. I will look at it and revert asap
I have found a way how to remove last landing step. And i add final banister. I tried to add balustrade but didn’t succed (stringboard is changing the parameters of the stairs), so i gave up.
Pls can someone reply to this mail so that i know that you received it and you gonna send me a dxf plans.
Brgds,
Zeljko
