Stair to garage loft|Forum|WOOD DESIGNER
Hi Claes,
I have opened the DXF files in AutoCad and all come up in millimeters normally.
I would suggest that the problem is that your AutoCad is set to inches. You’ll have to set units to millimeters before opening the DXF files.
If you are having problems try using the free CAD program Draftsight.
Hi Claes,
I’m sorry, but I’m on holiday this week, I’ll have a look a your project next week .
I’m on this project again. When I’m trying to use the DXF files through Autodesk Viewer or eDrawing it opens up with INCHES as units but the measurements are in millimeters. If I change the units to millimeters I get a huge stair. Is this caused by some setting when you’ve produced the files?
Kindest regards
Claes
Hi Claes,
I would try to build this stair as one piece to be raised or lowered into the stair well.
If there is not enough room to assemble the stair like this, I would use a 3 part wall stringer to assemble the stair in the well.
See this article:
https://wooddesigner.org/stair…..vironment/
Hi Ness, thank you very much for the files.
I’ve now started to build my stair. I have som thoughts about the assembly… Will the stair be assambled in one piece or will
each flight be one piece to be merged when placed where it shall be used?
Thank you very much in advance!
/Claes
Hi Claes,
Here are you files.
Hi Claes,
Sorry about that.
Here it is…
