Stair to garage loft|Page 2|Forum|WOOD DESIGNER
long time no seen. I’ve been busy doing other things. I’ve now found a place where I can buy the material for the stairs and I’ve changed the dimensions of the stair to the available dimensions of the material.
I would really appreciate if you could check my file if the stair will work. I think you made some changes with my former version of design in order to get it easier to build?
I’m a newbie into building stairs so I think everything that can make things easier would be appreciated.
Kindest regards
Claes
Hi Claes,
Reducing the thickness of the stringers will change the geometry of the stair and although possible, I would not recommend it.
If it’s impossible to maintain the 50mm thickness the best solution would be to change the thickness in StairDesigner and regenerate the plans.
The next best solution would be to maintain the position of the inner machined face of strings.
This would enable you to not change the step shapes and routed housings but will require offsetting the inner strings on the post. This would make the stair 10mm less wide on the outer wall side.
How far have you got in the building?
Hi Claes,
Here are your working documents.
You can print full size templates by loading the dxf files into a CAD program and printing from the program.
If you don’t have a CAD program you can download our free Draftsight program using the link on the members free ressources page here:
https://wooddesigner.org/membe…..raftsight/
With Draftsight, you can also add dimensions to the dxf drawings if necessary.
We can send you PDF files of the parts but this takes some time on our part and is only part of our paid StairFile Pro service.
PDF can be useful if you are using a subcontractor for printing.
You can print pdf yourself by sending the Draftsight print to a PDF printer like PDF Creator.
Good luck with the building of your stair.
Keep us updated on the progress.
Hi Claes,
I’ve made the outer string straight so that it will be easier to make. However, this makes StairDesigner project it up and not round off the upper corner. You can correct this simply by cutting the upper corner to the correct height and shape when you make the stair.
If the project is ok with you can I send you the working documents?
