Stair with winder turn not 90 degrees|Forum|WOOD DESIGNER
Duayne Naugle
Forum Posts: 130
February 17, 2019 - 1:24 am
Interesting !
February 11, 2019 - 10:30 am
Hi Michel,
Thank you very much for the video.
It explains everything perfectly.
Mike
February 8, 2019 - 7:42 pm
Hi Michael,
I made a  video to explain how it is done
(EDIT: video no longer active)
February 8, 2019 - 2:25 pm
Hi Michel,
The wall sizes 1050,2280 are definately correct, as is the width points, the angled back is based on a line drawing I did with a scale rule, so if we go with the sizes you have there, I am happy with that.
If you can let me know how it is done that would be great.
February 8, 2019 - 1:34 pm
Hi Michael ,
There is something with the measurements . See my plan and the red measures . this can perfectly be done in SD7  but we need to be sure on the measurements
February 8, 2019 - 12:52 pm
Hi Michel,
Hope that upload is succesful.
MIKE
February 7, 2019 - 5:46 am
Hi Michael,
Glad you found a solution to it on the site.
Can you post your stair so that I can  look into your problem?
February 6, 2019 - 12:05 pm
Hi Stefan,
Ive found something on your site that helped, but what I cant find is how you vary the widthe of a stair from top to bottom. I have a stair with right hand rotation and the right hand stringer and  turn are 90 degrees, and into a newel post, but the left hand stringers which are against walls are obtuse.
Can this be done in stair designer?
Forum Posts: 956
February 6, 2019 - 11:55 am
Hi Mike, I’m not sure we have a specific video that references this issue. Michel is reviewing and will get back to you. Thanks
February 4, 2019 - 4:41 pm
Is there a tuition video on version 7 for how to draw a stair with a turn angle different to 90 degree?
Guest(s) 49
Christian GLENET
mohammadmaghari
Petru
Trojan Construction
Islam Boukouiren
Topics: 2970
Members: 566
