Stairdesign measures|Forum|WOOD DESIGNER
michel melon said
Hi Gullik,Are you using the demo version ? Detailed measurements are not visible if you use the demo version
you can only see the parameter values of the stair
Attached the top view of your stair . I think you made a mistake by using step recess instead of step penetration in the stringboard parameters. Your steps are now 30mm shorter on each side and do not penetrate the stringboards
Also please try our new software stairdesigner 7.
Hi and thank you. Yes, we are using the demo version. Asked about the code when we upgraded to premium, but was told we didn’t need it since we could post it here on the forum to get it finished with measurements.
Regards Gullik
Hi Gullik,
