Stairdesigner 7|Forum|WOOD DESIGNER
Hi Hasse
yes you can 😉 . You have to check regularly as the program get regular updates
https://wooddesigner.org/suppo…..-download/
Hi Hasse ,
I made a small video showing you what I did to get the connection. However it possible that when you displace or enlarge the newel that suddenly cutstrings are disappearing. This is because the newel is cutting through a step from front to back. This creates that problem.
Ness can surely give you more information on this if this is reported as a bug or not.
Hi Hasse
have you updated your software to the latest version yet ? 7.04D
February 18, 2014
I have now spending hours to find out.
I have also tryed to make a new stair whith same measure.
And I do not delete anything but after measures i click in cutstrings and then posts.
Wen I click in handrails some of cutstings dissapear.
I have tryed several times.
So I wonder…. is it some problem with my softwear???
I bought it in july 2016 with reduced price.
Is it update??
It can not be so difficult.
Hi Hasse
I downloaded your file and all I had to do is change one of the two posts to handrail and the connection is ok . I can not give a clear explanation on how this is working right now. I wil come back with a more detailed explanation on this. try it from your side now and you will see it connects immediately. Let me know if it works at your side
February 18, 2014
I am working in original.
I have seen the high tops beacuse I have change it
Now I changed back to 50 mm over hl.
Still the gap. even if I shift post 5,6 reference axis betwen automatic and handrail.
It is still gap.
and if you see in 3d this two posts are verry low under the handrails.
Its good if you can fix it but I must also new why so I can sucsess by my self next time
Hi Hasse
in the tab view on top of the screen you can choose display handrails.
I wonder if you opened the file I send you or are you still working of your original one ? Can you tell me which changes you did ?
Again I see a much too high newel above the handrail in the settings. Newel 5 reference axis is on automatic and newel 6 on handrail. Change newel 5 to handrail and it will connect correctly . Then change the top height of the newels to correct them.
I wonder were these high values of top height are coming from. Did you set them ?
