StairDesigner Customization|Forum|WOOD DESIGNER
October 11, 2018 - 4:15 pm
Hi Cathleen,
Arcs can be set up precisely with various parameters that are in the coordinates drop down list:
arc-parameters.jpgImage Enlarger
To get the precise arc you require it’s easiest to set up the general plan in CAD and add dimensions to locate the exact position of the arc centre and the arc angle. Then using the appropriate coordinate system input the values.
It’s actually impossible to create a landing with 2 flights leaving the landing. We are hoping to add this to a later version. For the time being you have to build 2 stairs and join them together in CAD.
October 11, 2018 - 3:59 pm
I was able to manually modify the stringer with more success, but it’s doing by eye, it would be nice to be able to input the actual radius for the section.
Floor-Plan-Drawing.jpgImage Enlarger
As well, I haven’t found a way to add multiple flights to a single landing, is something like that possible?
Second-Floor.jpgImage Enlarger
Thank you so much!
October 11, 2018 - 10:11 am
Hi Cathleen,
Our free version has all the full activated versions functionality except the manufacturing output.
Here’s an example of a flared stair done with StairDesigner:
flaired-stair.jpgImage Enlarger
I also attach the StairDesigner file so you can see how it’s done.
To fully understand and answer your question, can you post a sketch of what you are trying to achieve?
October 10, 2018 - 11:05 pm
I recently installed the demo version of the StairDesigner 7.06, and have been playing around with the functions and abilities. Our company is looking at a few different design programs like this and so far yours is proving to be the best. Your tutorial videos are fantastic. I’ve been quickly putting together some of the staircases we are currently working on with fairly accurate success however I’ve run into a road block but can’t seem to find a solution. Is there a way to add a curved section of stair that flares away/opposite the radius of the curved staircase. I was able to make a version where I manually altered the stringer, but it is incredibly choppy and it affects the handrail and spindles. Is there a function or setting that I’m missing? Is this a tool only available once the license is purchased, or this capability available?
Most Users Ever Online: 704
Currently Online: Zaki Brijawi
Guest(s) 80
brendan kavanagh: 205
Conor Devoy: 158
Zaheer Abbas: 154
Patrick Maylor: 108
Tom Jackson: 106
Maciej Jaworski
Eleanor Maple
Filip Godu
Erik Rickert
Brandon Januarie
David Triller
Nathan Bruton
Michael Okyere
Timo Pitkänen
Topics: 2725
Members: 470
