stairwell on 3 sides of stairs|Forum|WOOD DESIGNER
Forum Posts: 2128
August 31, 2023 - 2:12 pm
You’ll find the stairfiles attached, so don’t hesitate to contact me if you need anything, or if I’ve forgotten anything.
Included standard DXF files for CNC
Dominic Mann
Forum Posts: 39
August 31, 2023 - 1:47 pm
Hi Michel and Alex
I have attached the most up todate drawing that we are going to machine.
If you could send me the parameters so we can get started.
Many Thanks
Dominic
Dominic Mann
Forum Posts: 39
August 31, 2023 - 11:44 am
Hi Alex
Here is the drawing file.
Dominic
Dominic Mann
Forum Posts: 39
August 31, 2023 - 11:33 am
Hi Alex
I have attached some pictures of the banisters we are using and just wanted to ask are they going to be in the program on the steps to be machined out?
They are 12mm at the bottom and go into 34mm in the middle so in my program I would put them down as 12mm thickness and 90mm apart or would I have to change that?
Once we have this sorted we should be ready to get the parameters off you.
Manny Thanks
Dominic
Banisters1.jpgImage Enlarger
Banisters2.jpgImage Enlarger
Banisters3.jpgImage Enlarger
Forum Posts: 2128
August 31, 2023 - 10:28 am
You must start with the landing step, because the landing level cannot be lower than the previous landing step.
Dominic Mann
Forum Posts: 39
August 31, 2023 - 10:10 am
Hi Michel
we are almost done with this stairs we just need to change the height of the stairs from 2927 to 2910 due to a change from timber floor to carpet on the landing.
is this possible to do this on our end and if so can you send me a video of how if it can be done.
Many thanks
Regards Dominic
August 22, 2023 - 3:55 pm
Hi Dominic,
The outside curve on the stair start is not currently doable as you like it in stairdesigner due to technical restrictions in relation to the step. However, the curve in the inner corner is possible, and I have added it.
About the steps from step 16 are purely visual. In the pictures I see in your earlier posts, the stairwell has already been made and is part of the upper floor. As long as your design fits perfectly with the size of your stairwell, there should be no problem, as you are not actually going to build these steps. Please look at the model I added and check that the shape and size of your upper floor match 100 % with the stair design.
Dominic Mann
Forum Posts: 39
August 22, 2023 - 12:57 pm
Hi Michel
I am attaching a dxf file of what we are trying to achieve.
the bottom three steps are curved
the handrail curved at the bottom
It also contains a drawing of the first floor plan and shows the layout of bedrooms and hallway
Ideally this dxf file needs to be converted or created to stair designer or as close to it if posable or a video on how to do all these steps are selfs
I would like to thank you in advance for all your assistance
Dominic Mann
Forum Posts: 39
August 21, 2023 - 4:04 pm
Hi Michel
I have added 3 pictures of what we are trying to achieve with this stairs.
Is it posable to curve the inside of the first landing by a radios of 200mm I have a picture attached with it marked in yellow.
Step 16 is what we are looking for but we dont need step 18/19 due to the wall been there so step 17 would also run into the wall as shown in the drawing i have done in the first picture.
I have attached a photo showing an overview of the stairs design, as you can see I need to change the landing on left to a wall with a doorway either side to allow access into bedrooms.
We dont need newel posts now we would be looking for a continues handrail if this was posable.
I hope I have outlined everything clearly, please come back to me if you need any further clarification
many thanksUp-Stairs.jpgImage Enlarger
Landing-Corner.jpgImage Enlarger
Plan-Drawing.jpgImage Enlarger
Dominic Mann
Forum Posts: 39
April 12, 2023 - 3:19 pm
Hi Michel
I have attached two pictures in a bigger format will yellow ring around them so hope you can see them.
I have also added a few pictures of the stairs that you helped us with a few years ago and some other stairs we have doneStair-Well.jpgImage Enlarger
Stair-Well1.jpgImage Enlarger
PHOTO-2023-04-12-14-41-01-1.jpgImage Enlarger
PHOTO-2023-04-12-14-41-01-2.jpgImage Enlarger
PHOTO-2023-04-12-14-41-01.jpgImage Enlarger
PHOTO-2023-04-12-14-41-02.jpgImage Enlarger
PHOTO-2023-04-12-14-41-05-1.jpgImage Enlarger
PHOTO-2023-04-12-14-41-05-2.jpgImage Enlarger
PHOTO-2023-04-12-14-41-05.jpgImage Enlarger
PHOTO-2023-04-12-14-41-06-1.jpgImage Enlarger
PHOTO-2023-04-12-14-41-08.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-40-59.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-41-00-1.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-41-00-2.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-41-00-3.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-41-00.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-41-01.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-41-04.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-41-05.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-41-07.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-41-19.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-41-20.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-46-32.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-46-34-1.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-46-40-1.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-46-40.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-46-43-1.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-46-43.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-46-44.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-46-45-1.jpgImage Enlarger
thumbnail_PHOTO-2023-04-12-14-46-45.jpgImage Enlarger
Drawing1.jpgImage Enlarger
Drawing2.jpgImage Enlarger
Dominic
Guest(s) 53
brendan kavanagh: 227
Emmanuel Sacco: 196
Carl O'Meara
polyjohn
Maxime Marengere
everslyjoinery
Topics: 2906
Members: 540
