March 1, 2015
March 1, 2015
i tried to download the files above but i do not have the current version , tried to download the newest version ,MS will not let me open it , says it is a file not commonly found , i had no problems downloading the last update , this one is different , could you check it out .
May 26, 2022
Hi Sandy,
Here is a first example but requires a lot of editing. Please check and revert if any comment
The following users say thank you to Michel for this useful post:
Sandy Thompson
May 26, 2022
I have just gotten stairdesigner and I am trying to use it to create a flared case that has the first and second treads returning to a wall. The rail would return as well. Can you help me break down the steps to make this? I have exported the stair designer file into sketch-up and tried to work it there, but it is not working out for me.
I've attached the sketch-up picture and a photo of the existing staircase that we are replacing.
