stringboard alignment|Forum|WOOD DESIGNER
August 30, 2022 - 11:59 am
Sorry for delays,
For step number 13 you can edit material to Nil or set set transparency of 100%
transp..pngImage Enlarger
After completing the configuration of your stair, you can edit the stringboards manually
August 26, 2022 - 6:20 pm
Good morning, I would like to know if the two parts of the stringboards ( the joint in the corner) is possible to have it aligned at the same height and not staggered as it looks in my draft. I would also like to eliminate step number 13 which is much smaller than the others and i don’t like it aesthetically. While i wait for your advice I already thank you who will help me. I’m attaching the draft so that if anyone wants to look at it and even correct it can do. Thanks again
Davide
Guest(s) 28
