TOOL CODE FOR BIESSE NO WORKING|Forum|WOOD DESIGNER
OfflineHi Sean,
Can you record a video of what is happening for us to look at? Otherwise, we will have to come in a video session, but we need your Biesse program on the video meeting to view the issue. So if you can send us a video of the problem as it should be working properly
OfflineHi Alex
Thanks for getting back to me .
The problam is only with this stairs the only tools i had in it when this started was the
hiteco1/2 aggregate
18str
16str
but i created the other tools to try fix the problam.No joy
i would rather use the 18str for the pockets and the profiling but it dosent allow this.
It looks like you have the same tool with the same name, but with different parameters,
It seems to me that the confusion in the export comes from here.
Could you delete your Post-Pro, and tools,
Then restore it from your PP you upload, then restore and set your tool again, I hope this will solve your problem.
It is possible that upgrading to 7.15D may also help you
Without uninstalling your version, close SD , download and run the installer, then follow the instructions on the screen
To upload your PP, you can compress it before as a zipped file,
with the standard Windows compressor, make right click then select “send to” > Compressed (zipped) folder
Did you use CID,CIX or DXF?
In DXF it is quite difficult because you have to know how to set up each layer with a specific coding.
OfflineHi Sean,
Can you send me your active postprocessor?
Just go to the file menu and into ” export options”
Select your postprocessor, and below there is an export button. Save the generated file and send it to me
OfflineHi i have been cutting straight stairs on my biesse with no problems .But today we started cutting an l shape stairs with all winders and it dosent like it i use a 16mm cutter for the step pockets but it seams to be looking for a 4 mm cutter to go arond the pocket but i dont know why.My steps are 39mm thick would this make a diffrence?
