Tread width|Forum|WOOD DESIGNER
Hi Serge,
Can you post your stair-file to have a look at. However, the thread width in stairdesigner is calculated from the step-nose of the first step until the step-nose of the last step divided by the number of steps which is the correct way to calculate. When you add nose space it will enlarge the steps but will not change the tread width as the distance between the step-noses is not changing. This can only change when the flight is extended or shortened.
Here is a little drawing showing the different aspects of the stair values.
January 28, 2020
Dear sirs, I’m new to this an I have a slight problem with the tread Width. It’s to low, or the software says it’s to low. I think it’s ok because I’ve added 50 mm nosing to the steps but it doesn’t calculate that. Is it normal? Can you please help me out here.
Thanks in advance.
Serge
