winder stair |Forum|WOOD DESIGNER
OfflineSean,
See the following video. This is not your specific stair, although is a generic video for shaping landings as winders. Additionally, you can move posts closer together with the previous method I showed you.
OfflineIsaac said
Hello Sean,
Firstly, don’t worry about the sound on the video, as I did not record any sound for that video.
Secondly, for your stringboard question, see the following video:
IsaacIsaac said
Hello Sean,
Yes, delete the newels and add them back in. Then you can adjust their position to suit your requirements.
Thanks Isaac.on the winder landing design could you do a video on how you designed it and can the posts go tight together on it?
OfflineHello Sean,
OfflineIsaac said
Sean,
See the following video for moving your newel posts:
What specifically is the issue with the nosing and string? Can you please send me an image of your concern?
Hi isaac. If you download dxf of Aaron’s stair look at string with posts top tread measurements is 69mm from edge of nosing to string but botyom tread measurements is 45 mm i will try and send dxf
December 4, 2024
OfflineIsaac said
Sean,
What specificalIsaac said
Sean,
Hi isaac I seem to be having an issue with the sound on video.i have volume turned up and its not in mute would you be able to advise.
Thanks sean
OfflineSean,
