Stairs with a quarter turn in them have been around since basic carpentry skills were first developed. The turn can be left or right handed and they are generally used to fit a staircase into a limited area, or to follow the lines of an existing wall, or fit around part of the building such as a chimney or door.
The popularity of quarter-turn staircases is due to their versatility and space-saving design, and are found in both modern and traditional homes. With unique aesthetic appeal and functional benefits, these staircases can add a touch of elegance and sophistication to any home.
Understanding quarter-turn staircases
A quarter turn staircase is, as the name implies, a staircase that turns a quarter at some point along the run. This design is particularly suitable for homes with limited floor space or for creating a dramatic entrance.
The point at which the turn occurs is governed by the space and angle available. The turn can complete anywhere and can include a small landing or a gradual turn. High turns occur at the top, mid in the middle, and low at the bottom.
Key features
- Compact quarter-turn staircases are perfect for smaller spaces as they take up less floor area below compared to straight ones
- An aesthetically appealing curved design in a quarter-turn staircase can add a touch of elegance and sophistication to any home or business
- Versatile quarter-turn staircases can be used to create a dramatic entrance or simply to connect different levels of a home while fitting into the area available
- Adapt them to fit various design styles, from antique to modern and everything in between
Design considerations
- The quarter turn is not a technically difficult element to incorporate into a staircase, so choose a material that complements your home’s overall look and style; popular options include wood, metal, glass and combinations thereof
- The size, angles and shape of the treads and risers should be carefully designed to ensure safety and comfort, especially when planning the turn
- A sturdy handrail is essential for safety and can also add a decorative element to the staircase
- Sympathetic lighting is crucial for both safety and aesthetics; consider under-stair lighting or spotlights to highlight the staircase’s design as well as ensuring the style of lighting goes with the rest of the house
Installation and safety
While DIY enthusiasts may attempt to install a quarter-turn staircase, it is often recommended to hire a professional for safety and quality assurance.
If you’re confident in your skills, you might like to give designing and building the whole thing a try by using our StairDesigner software. We are here to help if you subscribe to our support package.
Ensure that the staircase complies with local building codes and regulations, and consider adding safety features like child gates and non-slip treads to prevent accidents.
Whether you choose a quarter-turn staircase due to spatial constraints, around a feature in the building or just because you like them, their compact design and aesthetic appeal can add a touch of elegance and sophistication.
